Sony Vaio Duo 13 - Current Issues
jamhall45
As far as I can tell, there seem to be 3 major issues with the Sony Vaio Duo 13.
WiFi Performance
Many users are reporting this (and I have the same problem).  WiFi performance is quite poor.  Quite often the wifi signal drops to 20%, and is normaly hovering around 60-80 %.  Other devices sat in the same room are showing 100% signal strength.
Pressure Sensitivity
The n-trig digitizer is not reporting the pressure sensitivity range correctly to applications that support the Microsoft Realtime Stylus API.  Applications affected are Artrage Pro, Sketchbook Pro, Manga Studio 5.
As it does not report the pressure range correctly, these apps set a default range of 1024.  The Duo 13 only supports a range of 256, so as a result, the applications treat even the hardest press of the stylus as a quarter of the maximum pressure range.  This is a major issue as apparently pre-release units did not have this issue.  In the US, Artrage is bundles with the Duo 13, and simply does not work.
Vaio Update not recognising hardware
Every time I run Vaio Update, it says :
Dear VAIO Customer,
You have arrived at this page because VAIO Update does not recognize your VAIO.
This may be a temporary problem with the VAIO Update server.
SONY, can these issues be addressed as a matter of urgency as the rather expensive device I have just purchased is unable to be used as its intended purpose.
James Hall
11 REPLIES 11
SHumayun
This if for the pro 13 but I'd be very surprised if there wasn't one for the duo out too
http://www.sony.co.uk/support/en/product/SVP1321C5E/downloads/EP0000306999_8876
ewoksco
any one having problems with wifi try unistalling mcafee. Worked for me
