Sony VAIO E Series Laptop
wandark
I have a Sony VAIO E series Laptop and it came with windows 7, recently the hard drive went bad so I bought a new one but when I installed Windows 7 on the new drive it Says "Windows could not complete the installation. To install Windows on this computer, restart the installation." I have tried over and over to reinstall and I get the same message....Any advice??
pctech33
You can easily install the Windows 7 in your computer after checking and ensuring the system requirements. You can insert the Original Windows 7 OS in your drive and reboot your netbook; this will make your netbook boot from the DVD. Follow the installation wizard and after the installation, enter the product key and then register the product at the Microsoft website.
http://www.tomshardware.com/forum/59586-35-reinstall-windows-acer-aspire-netbook
Hope this information helps you.
_______________
Life is too serious to be taken seriously http://imagicon.info/cat/12-13/text-smiley.png
pctech33
_______________
