Sony Vaio FE41S - Sound driver for WinXP needed SP2
Gabro86
I bought a Sony Vaio FE41S with Vista preinstalled. Now i have deleted Vista and installed Win XP SP2.
All driver except the Sound driver works. Where can i find sound driver for Win XP SP2?
4 REPLIES 4
profile.country.de_DE.title
seb21__
Download KB888111 via Windows Update.
bassmann5
I used the one that came with the 31Z. Although I´m certain Sony does not support this, it worked for me.
On the other hand I´m still looking for camera and bluetooth drivers. Which ones worked for you?
Greets,
K.
Gabro86
Thanks for the replies.
Everything works now.
I used the FE31Z drivers.
For bluetooth and camera i use the Vista driver which are included in the Recovery Partition. You should install it by selecting "Update Driver" under the "Device Manager".
bassmann5
Same here, everything works now.
Thanks, K.
