Sony Vaio Fit 15A SVF15N display issues
JackOO7
Touch screen is getting several touches, or is it Clickpad?
As a workaround I have to disable it.
1 WinLogo+x
2 devicemanager
3 HID- touchscreen, disable devise/(or enable if needed). Yes.
4 Restart not noneed
The other issue is in display, it has lines, or even black screens. Time to time.
I have not figured what the reason is.
External display is working fine with HDMI-cable.
Any ideas what can be done? What is the root issue? :grin:
Sean_Mc
Moderator
Hi Jack,
It would be best to get in touch with the support team for help with this issue.
Best wishes,
Sean Mc
