Good evening!
I have a sony vaio pcg-7x1m model and i cant find drivers anywhere.
i dont know if there is a recovery disk,but i want to make a clean install with only the models drivers on.
i cant find it on the support site because it is an old model,so i ask here for some help.
thanks in advance.
Solved! Go to Solution.
Hi webassasin,
You are quoting the chassis reference which is probably why you can’t find the model on the Support site.
Have a look on the screen surround for the product number – possibly a VGN-Nxxx
Rich
Thank you so much for the fast response.
You're welcome :)
