Hello,
I can't find the drivers for the notebook Sony Vaio
Acutally, at this time I need the webcam driver and software.
Any advice where I could find it?
Thanks.
Solved! Go to Solution.
There's nothing on the screen which should identify the notebook but I've found it using the 15 character serial number.
Thanks for your help.
Haris
Hi and welcome,
The reason that you can’t find drivers is that you are quoting a chassis number and not the model. Have a look on the bottom right hand side of the screen surround for the model number which will probably be VGN-AR51 and then have a look here:
http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB&m=0&old=n&s=VGN-AR
PCG-8Z2M is not a valid model type. It is the chassis model which can be shared with several Vaio Models - so you will not find any reference to it in the support pages. Have a look on the screen surround and you will see the correct model - it will be something like VGN-AR51J.
You can also find the model in Control Panel -> Vaio Control Centre. When you have the correct model, you can lookup the drivers here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-AR51J
