sony vaio PCG FR215S
ckfk
I recently had a software problem with my laptop and therefore had to reinstall everything.
It all seems fine now except for one thing
i cant seem to adjust the volume using the "fn" keys on my keyboard. i have had a look in several settings but found nothing.
I currently cannot find the manual and so cannot look in there.
someone mentioned to find the manual from the webpage but then i was told that its most likely not in the manual ?! :thinking:
can anyone help?! I'm not very good with computers
:slight_frown:
kee-lo_
Make sure you install the Sony Shared Libraries.
nick_pan
yeh the fn keys need drivers..which can be installed off ur sony resources cd that came with your laptop...
