Sony Vaio Power management doesn'e work anymore
puppets
Hi All :slight_smile:
The otherday my application Vaio Management stopped to work, I got an error message saying that an error had occured and the application was shut down. It hasen't worked since. :cry: Has anyone else here had the same problem?
I have a Sony Vaio VGN-FS495VP
Best regards
Jonas
Hi Jonas,
You will have to reinstall the Power Management Utility.
In explorer, navigate to C\Utils and double-click on Utils.exe to run it and reinstall all your Sony Utilities.
If this does not work, you will have to download the Preinstalled Utilities from Vaio-Link and reinstall
1 SonyUtils DLL
2 Sony Shared Library
3 VAIO Power Management
Once they are all installed reboot your Vaio..
You may have to do this several times..
Have a look at this
Similar Thread
:wink:
puppets
Hi Blencogo :slight_smile:
Thanx for the advice, I have tried to reinstall everything and I have all the Vaio options now, but it's using the microsoft application for power management. I guess that will do.
Really great of you to take your time and help me. I really appreciated it! :grin:
Best regards
Jonas
Glad you've got it sorted Jonas.
If you want the Sony Power Management to work, you may find you have to reinstall the folders more than once!
:wink:
