Sony Vaio VGC-JS1E/S Start Up Problems
comccal70
I was half way through editing a movie for a local competition in Glasgow when the computer suddenly shutdown and have been unable to get it to restart. When I plug the jack into the power port and depress the on button I get the start up sound but no light appears to indicate it is on. Regards
Colin
rich912
Hi Colin,
This is a possibility but you will need to confirm this with a competent repairer.
I have used the following company for a similar problem with good result. Cost approx. £120.
http://export.tv/r/19859/ACi-Ltd-Laptop-Motherboard-Repairs/index.html
Or you could contact one of the Sony Service Partners via the Support tab at the top of this page.
Rich
Go n-éirí an bóthar leat
5 REPLIES 5
rich912
This is a long shot Colin but remove the power supply and then hold down the power button for 30 seconds. Re-connect the AC adaptor and try booting the computer.
Rich
comccal70
Hi Rich, Thanks for your reply. Tried out your suggestion but unfortunately the damn thing decided not to comply. Maybe a bit more serious than I originally thought. I was trawling through the net an read that the problem may have something to do with a faulty power jack socket. Is that a possibility.
Colin
rich912
Hi Colin,
Rich
comccal70
Thanks for your reply,..and yes it was a motherboard problem and took it into a local repairer. Cost me a bit more than a 120 and discovered the HD was fried. No luck, eh! But thanks all the same.
Colin
rich912
You're welcome Colin and pleased to hear that it is now fixed.:smileyhappy:
If you could mark your thread as solved it would be appreciated.
Rich
