Hi All,
I am having above Vaio model since last two years. I need to upgrade the Processor from Core 2 Duo to Intel I5, and also my graphic card from ATI HD 3470 256MB to 512MB Is it possible?
Also is it possible with current Specifications(Windows Vista Home Premium 32 bit) to upgrade to Windows 7 PRO 64bit system?
Thanks a lot in advance for your valuable inputs.
Solved! Go to Solution.
Bad news I'm afraid.
You cannot upgrade the processor to Intel i5 - it is a different socket. Also because of the new I/O interconnect, chipsets and mainboards from previous generations can no longer be used with the new i3/i5/i7 Nehalem based processors.
The Graphics on laptops are not an interchangeable card but are chips soldered into the main board and cannot be economically upgraded - it would cost more than a new laptop.
You can upgrade to a 64-bit Windows system but Sony does not support Windows 7 or 64-bit on your model so you will have to hunt down all the 64-bit drivers individually. You will also lose all the preinstalled Sony software because you cannot upgrade to 64-bit from 32-bit, it will have to be a clean installation of a commercially available version of Windows 7.
@Blencogo
Thanks a lot for reply. But Can I upgrade to Windows 7 Home premium 32 bit? Thanks
Download and run Microsoft's free Windows 7 Upgrade Advisor: -
http://windows.microsoft.com/upgradeadvisor
This will check all your programs, devices and drivers and tell you what is not compatible with Windows 7. You will probably find 2 or 3 devices are currently incompatible and you can then find Windows 7 drivers before you upgrade.
If you buy an UPGRADE version of Windows 7 HP then all your preinstalled software, utilities, programs, settings and data will be preserved. You need to run the installation as an 'Upgrade in Place'.
http://www.amazon.co.uk/Microsoft-Windows-Premium-Upgrade-Vista/dp/B002DGS81C
Thanks Blencogo..:smileyhappy:
So instead of upgrading hardware better to go for new one...:smileyshocked:
