Hello
I have clean install Windows7 (64bit) and can't find drivers for function keys. Works only Volume
Buttons: ASSIST, WEB, VAIO don't work too.
I can't also find drivers for webcam.
All the Original Drivers for your Vaio are available for download here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCEB2Z1E_BQ
If you install all of there everything should work. There will also be updates available under ther UPDATES Tab.
Unfortunately, preinstalled software cannot be downloaded and can only be reinstalled as part of the original Sony Operating System. You will have to purchase camera software if you bave changes the operating system.
