Sony VGN-FS295VPF Windows 7 Drivers
Mpakogiannopoulos
Did anyone try to install win 7 in Vaio notebook VGN-FS295VPF? :neutral:
Sony do not even support Vista on this model - let alone Windows 7.
Try running the Windows 7 Upgrade Advisor to see what drivers you will need to find and what hardware will not work: -
http://windows.microsoft.com/upgradeadvisor
My thoughts are that you are very much better off sticking to XP because you will lose all the Sony software and several functions - such as the Fn Keys - will not work properly.
:wink:
:wink:
