I have sony VGN N 31S/W notebook. I want to install windows xp on my notebook. Can I install windows xp on this model. and from where i can have drivers for windows xp for this model.
Looking forward to helpful reply.
Regards
Nadeem
I have the same laptop as you and wanted to try and change to XP.
Having searched I found this thread on another Sony forum:
http://club.vaio.sony.de/clubvaio/DE/de/forum/viewthread;jsessionid=5073311BF103AB3528AFFAB8A809A7E1...
Not quite the same model - Z rather than S but I think for drivers they are the same.
Not tried them yet though!
Andrew
Hi Nadeem
1- Yes you can install windows xp with N series I have also N series laptop and I have install windows XP yesterday, also you can get all drivers from the link below. You will need the Drivers and Utilities for the VGN-N11 Series of Vaios that were made with XP installed.
This thread should help you download the drivers to install XP: -
http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=45485
2- All the N38 series can use the N11 XP Drivers.
The only main difference with the N38 Vaios (N38E, N38L, N38M, N38Z) is the processor and amount of memory installed - these do not have seperate drivers.
Good Luck - come back here if you have any problems.
