Sony VGN-NR21z/s with NVIDIA GeForce 8400M GT Graphics card
wee_tam
So, i bought this from ebay, with win 7 freshly installed, its in good nick, with the exception of the graphics card has'nt got the required drivers.
ive searched all over for the right driver but cant find it anwhere, does anyone have a link to the right driver please?
Regards
Tam
Message was edited by: wee_tam
8 REPLIES 8
rich912
Hi Tam,
Sony don't appear to have released a Windows 7 driver for this model. Have you tried installing the original Vista graphics driver?
http://www.sony.co.uk/support/en/product/VGN-NR21Z_S/updates
If that fails to install you may need to resort to a driver released by Nvidia in combination with a modified Inf file. See here for more detail - read the quick start guide towards the bottom of the page.
http://www.laptopvideo2go.com/
Rich
Go n-éirí an bóthar leat
wee_tam
yah... it said something like "windows has detected you are not using vista. program will terminate"!
helpful huh?!
rich912
Obviously not compatible with Win 7 then.
You will need to investigate the second link...
Rich
wee_tam
having a look at that now, not making much sense though i have to say haha
wee_tam
i cant find in which folder in the NVIDIA installations file to store it
any clues?
rich912
You have lost me...
If you are asking where to store it on your hard drive the answer is it doesn't matter as long as you know the location.
Rich
wee_tam
so i can put it pretty much anywhere and it will still run then?
rich912
If you are referring to the Nvidia driver folder then yes, but you must replace the .inf file within that folder with the modified version prior to the install.
Rich
