Sony VGN-NW24S How do I update the BIOS.
Hi all,
I have searched high and low both here and on the wider internet before asking this, but can any of you please direct me to where I can download the latest BIOS for my Vaio please?
It is a VGN-NW24S running Windows 7 64bit SP1
The current BIOS is showing as American Megatrends Inc 2009, so I would imagine that there have been some updates since then, although I am struggling to find it! Vaio update shows no new updates either.
Thanks for your time and if you need to know anything else then please ask.
rich912
Hi Huckmeister,
There is no BIOS update released for this model. Updates are only normally released by Sony if there is a problem.
Is there any particular reason you are seeking an updated BIOS?
Rich
Go n-éirí an bóthar leat
