Sony VPC-S13L8E 13.3 inch Intel Core i3 Laptop blu-ray upgrade
@3161488401013264
hi i have the SONY VPC-S13L8E 13.3 INCH INTEL CORE I3 LAPTOP,WHICH IS A VERY GOOD MACHINE is it possible to upgrade the dvd drive to a blu-ray drive preferbably with a  burning drive.if so where and which ones fit
thanks roy latham
All things are possible but you need to check you have the processing power available: -
http://www.eshopbrokers.co.uk/products/Storage/Blu-ray/Sony-Optiarc/Sony-Optiarc-BD-5750H-Disk-drive...
However, the cost will mount up as you will need the drive, some blu-ray player software and BD Burning software.
:thinking:
:thinking:
