- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
October 2011
October 2011
hi i have the SONY VPC-S13L8E 13.3 INCH INTEL CORE I3 LAPTOP,WHICH IS A VERY GOOD MACHINE is it possible to upgrade the dvd drive to a blu-ray drive preferbably with a burning drive.if so where and which ones fit
thanks roy latham
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2011
October 2011
All things are possible but you need to check you have the processing power available: -
However, the cost will mount up as you will need the drive, some blu-ray player software and BD Burning software.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2011
October 2011
