when i play a music cd on media player, when i change the size of the visulisation to full screen the sound jumps for a second when it changes. any ideas?????????
memory maybe, but probably our <profanity removed by moderator> NVIDIA graphics cards we have onboard, wish i had an ATI 9700 like they used to put in. i get this too especially with iTunes when converting music even without visualisation the cursor has serious lag over the iTunes window and i have 1 GB of ram also the music skips/stutters often when reading from my external hd (firewire)
anyone want to buy an S3XP only 1 week old!?
hi there again is your s3 still heating up warm? mine is i had it sent to sony they recon its normal.
anyway could you do me a favour please, play a music cd through windows media player, view the visulisation then double click on the image, it will now go to whole screen then make the skip noise.
yep my s3 is still warm underneath but i can get over that it isnt that hot its almost comfortably warm underneath my right palm. a friend has a HP p4 laptop and that is almost on fire on your lap!
RE the media player bit, yes mine does do that which can be a tad annoying, it seems fine with dvds though which is probably more important for me
i think the player thing is a driver problem, i am going to ask sony about it, i will let you know the outcome.
