Sound Problems
len112
Sound Problems
I have a new Vaio pcv rs704 , I keep on having repeated sound problems where the system becomes incapable of playing any sound , this is fixed by a restart of the system , however the system close down tune plays fine as the system starts to shut down , this fault has continued to occur even after performing a system recovery . Is this a freak fault or has anyone else had this problem . The only new hardware i've added is a Dinovo bluetooth keyboard and mouse
GBS
I dont know about your model, but it might be worth checking to see if there is an updated Audio Driver for your model at
http://www.vaio-link.com/downloads
Hope you get it sorted soon, no music would drive me mad!!!
