tukz
Soundbar FE 41 S
Hey all,
i had installed XP at my FE41S. I had installed all drivers but which utility must be installed to use the soundbar over the keyboard. I mean the buttons u can push to get louder oder mute ...
I hope you can helpme!
greetings
Thalamus.
Champion
Download the Preinstalled Utilities for your FE from Vaio-Link, once downloaded extract and then install the following, in order.
1 Sony Utilities
2 Sony Shared Library
3 Vaio Event Service
Once completed then re-boot your vaio.
You may have to do this more than once..:smileywink:
Litos
Hey all,
greetings
I had installed XP also but I can't install drivers... How did you get the XP drivers? In the support page I can find only drivers for Vista... I tried to install Vista drivers in XP but I get an error...
Could you help me, please?
Sassilein
Hi there!
I also installed XP professional on a third partition on my hardrive.. But I really cant get the sound to work.
I have a VGN-FE41s.
Under Vista sound works.
There are no XP drivers available on the Vaio hp.
But I managed to install everything by searching the web and using everest.
Now, please help me with those darn sound drivers.
I also installed the KB888111..
Please help me.
Thanks Sassi
