Spares for a Vaio PCG-F809K
kbbit
Does anyone know of a parts supplier in the UK for Vaio parts? Specifically I need the system board, a keyboard and a 30GB Hard Disk. Failing that if anyone's got a Vaio PCG-F809K with a broken screen they want to sell I'd be interested.
kee-lo_
The 30GB hard disk is a doddle, Dabs.com have that.
The rest you would have to try ebay or some other dealer, it's not easy to find here
Woody27
As Kee-Lo says getting the rest in the U.K. is hard!
Try Impact Computers:
www.impactcomputers.com
They are U.S. based but they stock most VAIO parts, are quick and relatrively cheap!
Otherwise as above, e-bay is your best bet!
Hope this helps!
CW
