spiderman trailer has started spontaneously appearing, touching a key clears it but how do i stop it happening?
petguest
A spiderman trailer . vaio ad has started spontaneously appearing, touching a key clears it but how do i stop it happening?
Thalamus.
Champion
Hi petguest,
welcome to Questions & Answers..:smileyhappy:
Sounds like the Spiderman trailer could be your vaio's screensaver..:smileyconfused:
To check click Start then Control Panel..
In Control Panel click on Appearance and Personalization, then Personalization followed by Screen Saver..
If Spiderman is your current screen saver then click on the drop down list and select another screen saver that you would rather use..
Thalamus.
Champion
Hi petguest,
