I hve a VPCZ11 laptop and have noticed when the laptop goes to sleep & then resumes, all is fine. If I hibinate the laptop & resume this also works fine - the desktop (screen) resumes exactly as I left it.
However, If the laptop goes to sleep & then auto Hibinates (after specified time by windows); when I switch it back on, it resumes but al my desktop open windows are 'resized' (all small & moved to corner of display).
I can then manually re-size them but this is a pain - any ideas how to fix this ?
Thanks,
T
Thanks,
T
I get a different effect. If I resume then the Vaio has real problems getting back into Speed mode, and starts running slow. The only answer usually is to shut everything down and restart the computer. I agree with your annoyance - the experts who help on this forum are brilliant, but the response from Sony (who created the problem in the first place) is non-existent.
