Status 0xc0000e9: HELP!
profile.country.NL.title
1213572
after this message you enter in a loop you cannot get out of. ASSIST doesn't work either, it leads to the same error message. any similar experiences and, hopefully, quick fixes? cheers.
KatherineYH
can you press ctrl + alt + delete?
Then click run task manager and in the let hand corner press run
Then type explorer.exe
_______________
Life is too serious to be taken seriously http://imagicon.info/cat/12-13/text-smiley.png
1213572
problem is i cannot start it up to begin with ...
