Streaming Music from PC on Windows 11 issue
DerekL3
I have a Bravia TV (KDL-40HX803) and have streamed Media from my PC running Windows 10 with no problem.
However, having just upgraded the PC to windows 11 it will not play media music.
It sees all the folders but when it gets to the .mp3 file it errors with 'No music files found'.
It does play video clips.
Can anyone suggest a resolution please?
Tags (1)
4 REPLIES 4
profile.country.US.title
tonwhite21
And on the computer everything is reproduced, maybe you have a problem with drivevirs?
Marino.Manolo
Genius
Try to check if through Chrome Browser you can send an .mp3 to TV via Chromecast.
DerekL3
I don’t have chromecast and Sony support have suggested a s/w update through usb. However, it doesn’t work as the tv seems to ignore the usb and I can’t see how I can force an update.
DerekL3
Found usb with tv s/w update had been formatted as NTFS. Reformatted as FAT and it worked with s/w updated on tv. However, no change to the problem.
