hi there
after installing I have problems with these drivers
Intel(R) HM76 Express-Chipsatz - LPC-Controller - 1E59
seems there is no driver installed
i did install the chipset drivers from here
http://www.sony.de/support/de/product/SVE1511N1EB/updates
didnt work yet
I updated the bios too
under gentoo linux i havent any problem and the machine runs just great
thx in advance
Hi casualx,
Are you referring to installing Windows 8? If so I assume you have carried out a clean install – this is not supported by Sony as most drivers are upgrades and require the original Win 7 drivers to be in place.
Only a migration is supported and you must opt to keep Windows settings, personal files, and apps.
The following upgrade guide may be of help.
http://sony.co.uk/support/files/vaio/EU1/Windows_8_Upgrade_Guide_EU1.pdf
Rich
