SVF15N1B4E AUTO ROTATE LOCK
go2clive
Hi all does any one else have a problem with there vaio fit 15 muti flip auto rotate staying locked after being in laptop mode,,and when you unlock from the charms still doesnt rotate,
even a restart doesnt work??
i have to completely shut down and then turn on to fix it,,,bit of a pain..
i have been intouch with sony and have said to do a systems restore out of windows mode,,
i told them i have done systems restore but with in windows ,,wich is the same is it not??
anyway Help Please!!
sgdavies
hi, its not happend to be, but does the following thread which refers to the tick box help?
http://community.sony.co.uk/t5/PCs-Accessories/SVF15N1C5E-Screen-doesn-t-rotate/m-p/1446616/highligh...
go2clive
Hi yep that's ticked.. I ended up doing what. Sony said and reset back to factory settings doing it outside of windows which has worked so far...
