SVT1311M1ES hard drive upgrade
naundrup
Hi, is it possible to replace the hard drive despite the hybrid drive?
My concernings regards the system files and cloning to the new hard drive. As far as I now the system files are located on the small SSD, so when i replace the HDD will i then have two hard drives with system files or?
I wan't to upgrade the hard drive to a Samsung SSD SATA. Should I install it as a single HDD drive or a slave/second HDD drive - considering the hybrid drive?
Anyone having experience with this?
Thanks in advance!
0 REPLIES 0
