System recovery disks for VAIO VGN-NR21J/S
LewandSony
Question : Due to hard drive failure I need
Full DVD factory recovery disk set
VGN-NR21J/S
PCG-7113M
Service tag C3LQNMEW
Windows Vista Home Premium
Can anyone help, please?
Regards
LewandSony
rich912
Hi LewandSony,
To order a set of recovery disks you need to contact Support on the out of warranty number (from the UK the number is 0905 0310006 (Fixed: 0.35£/min)). Have your serial number to hand.
Rich
Go n-éirí an bóthar leat
rich912
Hi LewandSony,
Rich
i.soleymani
Hi Rich
I have lost my original windows on my sony vaio model VPCEJ1Z1EW any idea how to get that in order to be able to make a recovery ? this is my email, would be great if you can reply on that if possible.
Message was edited by: rich912
Edited to remove email address.
rich912
i.soleymani wrote:
Hi Rich
You don't give us much to go on but the options are to either purchase a set of recovery disks or, if your recovery partition is intact, tap F10 at boot to enter the hard drive recovery utility. Be aware that this utility will format the hard drive and you will lose all personal data and third party software.
Rich
