Hi lads
Can someone help us the taskbar on my computer has turned white is there any way to get it back to the origional colour blue,On starting the pc it reported it had recovered from a serious error since then it has changed to white the taskbar
Thanks.
Hi Liam,
are you probably running in secure mode? Or else, check display settings, there is a tab for the windows themes. There you can switch to the Windows XP Theme again (it sounds like this is your prob)
Greets Michael
