The Fn button wont work
profile.country.sv_SE.title
Maskukert
Hey, Just reformated my Sony Vaio VPCF22L1E and I have installed all the drivers from the sony side, but still the FN shortkey wont work. Well... the mute and volume + and - are working but not the rest like the screen brightness and so on.
Any ideas of what I shall download or to get it work?
(Yes I totaly reformated the laptop so none of the pre-installations are left, because I wanted a clean format)
Wich I think sony has made a bad descission about this that there isnt any kind of complete installation of drivers and utillities to download after a reformat. And that you're not allowed to get the vaio uppdater what so ever after an reformat :slight_frown:
Thanks in advance, your Maskukert :slight_smile:
rich912
Hi Muskukert,
Have you downloaded and installed 'Sony Shared Library' and 'Sony Notebook Utilities' - In that order?
Rich
Go n-éirí an bóthar leat
rich912
Hi Muskukert,
Rich
Maskukert
That solved the problem, thanks alot Rich once again :wink:
rich912
You're welcome Maskukert:smileyhappy:
