The Vaio Fit 14 - how to change the battery?
01september
Recently I ordered a Vaio Fit 14 and I did some research on it. I found out that the battery is built within the computer and cannot be removed manually. If the battery (after some years) gets poor or even critical, do I have to send it in to a Sony Center for them to fix or will my own insurance cover it?
- A little confused here, the Vaio I have now has a removable battery.
2 ACCEPTED SOLUTIONS
Having Googled a bit, it looks like the Vaio-Fit 14 just has a normal clip in battery VGP-BPS35A.
Here is a spare one for sale in the US: -
http://www.love-battery.com/product_detail.asp?id=9800
I can't find anything in the UK yet or if there is a high capacity option.
01september
I found out the backside has a lot of screws, so it can probably be removed manually. Thanks!
4 REPLIES 4
Hi 01september and welcome to the Sony User Community.
You could always ask the Sales people on 0207 365 2413.  There seems little information online except that the battery is a VGP-BPS34.
I'll see if I can find out if the battery is like the old S and Z series (which require a screwdriver) or if it needs returning to Sony for service like the Tablet.
:thinking:
01september
Thank you. I hope you can find out how the battery works - also, if the battery can be removed manually, can I change it to a new battery that lasts longer than the standard one? Because the Vaio Fit seems to have a fine battery life, but I'd like for it to last a bit longer.
01september
