TnL videocard
beano1966
TnL videocard
hello
after installing a game on my rx301 I got the message
"this game needs a TnL compatible videocard" I know I can`t install another video card so. 2 questions.
1 what is TnL ?
2 any soloutions to my problem ?
thx
5 REPLIES 5
kee-lo_
1  what is TnL ?
http://www.driverforum.com/graphics4/3194.html should point you in the right direction :slight_smile:
robpaxton
T & L stands for Transform and Lighting - it allows a lot of the graphics processing to be carried out by the graphics card hardware.
The only solution is a replacement card.
kee-lo_
Yep, it's a large step forward for the gfx card makers, and ensures better rendering.
beano1966
ah well thats me stuffed then
but i`m gratefull for the info
thx all
kee-lo_
I would wait to get a new graphics card, they move so fast, but I feel that they're going to settle down in the next few months.
