Hi all i recently formatted my sony vaio vpceb3loe laptop and i erased all the factory settings. it seems as if its deleted the touchpad driver becuase i cant find an option in mouse settings to turn the tapping click off for the touchpad. Any help would be greatly appreciated
thanks
chris
Solved! Go to Solution.
Hi Chris,
You will find the original touchpad driver here.
http://www.sony.co.uk/support/en/product/VPCEB3L0E_BQ/updates
Rich
Hi Chris,
Rich
Cheers Rich!
You're welcome Chris
