hello everyone, i just clean-installed (without using the recovery disk) my A317M and everything's OK, except............. my touch pad's right side, which has to, normally, do the scrolling trick, but then again, it doesn't... any advice, software, driver will be appreciated! thanx! :smileygrin:
I think Windows has installed your touchpad as PS2 mouse. You must download the driverpackage from VAIO-Link.
Then go the properties of the PS2 mouse, click drivers, click update.
You must uptdate the PS2 mouse driver with the touchpad driver. That's all.
thank you! it's done!! :smileygrin:
no problem
no problem
