touchpad scrolling stopped working
colyford1
I was disabling items on the startup manager, and in some cases deleting items in order to speed up the startup. My touchpad scrolling function has now stopped working.  I'm using vaio VPCEB3JOE laptop with Windows 7.
My control panel device manager shows 'Mouse and other pointing devices' and then shows 'Alps pointing device' but there is no option to enable or disable the scrolling function.
Can anybody please help?
Many thanks.
rich912
Hi colyford1,
Have you tried reinstalling the original touchpad driver?
http://www.sony.co.uk/support/en/content/cnt-dwnl/VPCEB3J0E/list#os1
Select  either the 64bit or32bit driver depending on your configuration.
Rich
Go n-éirí an bóthar leat
rich912
Hi colyford1,
Rich
colyford1
Thank you very much indeed, Rich. That has solved the problem.  Verymuch appreciated.. Mike.
rich912
You're welcome Mike:smileyhappy:
Rich
