touchpad Vaio VGN-FW41E
profile.country.de_DE.title
SabineO.
Hi, I need to deactivate my touchpad as the cursor is constantly jumping. My Vaio VGN-FW41E hasn´t got a key with this function. Urgent!! I can´t work like that. Any ideas?? Thanks!
rich912
Hi SabineO,
You should find the option to disable the touchpad in Vaio Control Center > Keyboard and Mouse > Pointing Device – uncheck ‘Enable' or click Advanced for more options.
Rich
Go n-éirí an bóthar leat
rich912
Hi SabineO,
Rich
