TV Card not working...
gsense
Hi all...
I have a RC102 with Windows XP. My problem is that my pre-installed TV card wont work.
I try and set the chanels up using Vaio Zone settings and when I tell it to scan for channels it simply sits there. The progress bar doesnt move and no channels are found.
The program will exit and I get no errors. I have checked all Services and everything seems ok.
The Card is recognised in Device Manager and I have checked the antenna (plugged a TV into it) and the signal is there.
Am I missing something?
Thanks in advance
G
0 REPLIES 0
