- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
TV TUNER FOR VGC-LV1S
hi there! i recently upgraded my computer to windows 7 (vgc-lv1s) 64 bit. i lost my tv tuner and i cant download it again.
any help please
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi airene,
Have you looked here:
http://www.sony.co.uk/support/en/product/VGC-LV1S/updates
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The original TV Tuner Driver supplied by Sony for Vista is for 32-bit systems only and Sony do not provide a 64-bit Version.
I believe your model has the Avermedia A313 Hybrid DVB-T Tuner and you will probably have to Google for a 64-bit driver. There is one here but I really don't know if it will work - it would be at your own risk: -
I see that the VGC-LV2 series has an Avermedia A313 Twin DVB-T TV Tuner card and was released with a 64-bit driver. It is not a Hybrid card, however, and I don't know if it uses a different driver.
http://www.sony.co.uk/support/en/product/VGC-LV2SJ/updates
It is possible that you can find an A313 Hybrid 64-bit driver on another Vaio model but it would take considerable time to search! One of the problems of a clean install and a change to 64-bit.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks so much.il try your suggestions and wil let you know.
thankks
