Hi, Topic explains the problem, i have TX and have used nero smart. It confidently starts the burning proces only in the middle to say it cannot. well if your solution is try another brand then yes, i have atleast 10 different types tried it happens with4.5 gb thing, and greater problem is it doesnt recognise dual layer at all. shall i have to replace the drive?
i am sorry if this topic have already been discussed but have looked till 1....17... , looking for help
and have noticed that there are few experts here , i really like to thank them for their much needed comments and solutions, and i am sure i ll be needing them a lot !:smileycry:
If you have a TX1 then there is a firmware update for the MATSHITA UJ832 drive on the drivers & updates area of Vaio-Link . Unfortunately, the page doesn't give details about what the update is designed to correct . . . .
