Unable to extract R0232U2.exe
rwetech
Unable to extract R0232U2.exe told I "sorry you do not have the permission to extract the file" and yet I am local admin any ideas why does the exe have a green padlock symbol on it?.
I have also installed the hotkey utility but the FN keys still do not work.
I have a PCG SRX41P with Windows XP SP1 installed.
13 REPLIES 13
profile.country.de_DE.title
seb21__
Maybe this file is password protect. But i you want install the hotkeys, then you must doubleclick "setup.exe".
But what is R0232U2?
rwetech
It doesnt request a password I'm afraid.
This is the info from the vaio website:
BIOS Upgrade R0232U2
This program will update BIOS on the VAIO models listed below :
PCG-SRX41P
PCG-SRX51P
PCG-SRX51P/A
PCG-SRX51P/B
This BIOS Upgrade fixes following issues :
- Add support for Microsoft Bluetooth Stack
1. Download Instructions
1. Download the file R0232U2.exe, and save it to a download directory (ex. C:\Download\).
2. Go the download directory, and double-click R0232U2.exe.
3. A popup will appear : This will extract all files to C:\Download\R0232U2\. Press OK to continue.
4. A popup will appear : All files have been extracted successfully !
5. Press OK to finish.
No mention of a password being needed.
I managed to resolve the hotkey issue after finding this link:
http://esupport.sony.com/support/pops/osmig/xpclean.html
And installing the sony shared library files and the ui library issue resolved.
seb21__
Sorry, I can't help you with an BIOS update, because I have never done this.
kee-lo_
Do you have WinZip installed?
rwetech
I have winrar installed, when you look at the properties of the file it says install lock. copyright of sony
kee-lo_
Strange that it doesn't work.
Take it you have re-downloaded the file?
rwetech
Yes I've donwloaded it twice. Why provide a file then have it locked makes no sense been searcing the sony websites for the application name Install Lock to no avail.
kee-lo_
Try installing WinZip.
If that doesn't work then VAIO Link need to be contacted.
rich912
This may sound a silly question but have you changed the original Windows operating system? It seems the only plausible reason for the file being locked.
Go n-éirí an bóthar leat
