Hi all,
I have buy a Vaio notebook VNG-B3VP and it seems to work fine.
I ask if is there any chance to get more than 1024x768 on the screen?
ps not on external screen of course.
Regards to all
Sardoal
try instalting the driver , frm the viao update .
Hi shawnjosep h18
I have tried install the driver from vaio update and form intel. but without good results
Rgds
Sardoal
right click on the desktop then click properties, then click on settings tab
The max. resolution of the B3VP is only 1024x768 pixels. This is the native resolution. You can't get more. Only if you change the screen.
