When i run sony update it says that it cant find this model information on the server.
Also when i try to register this computer it says that it doesn't recognise the pc numbers.
Did anyone had the same problems and was able to solve them?
Hi yvesleon,
welcome to Club Vaio..
We have had post similar to this in the past, the registration problem is normally due to Sony not uploading your Vaio's serial number, if you can telephone Vaio-Link and explain your registration problem, hopefully they will then upload the serial number for you..
You can find the contact details for Vaio-Link here
