Hi
This is my first post. I have a PCG-TR5MP notebook (1.1GHz Pentium-M ULV processor)
Can anyone advise if this lovely little notebook will allow any upgrade of the CPU or HDD?
I like the machine a lot, but I would it would be great if I could run it a little bit faster.
t.i.a. any replies
I have one too.:smileygrin:
You can upgrade the HDD to a larger one, but make sure you buy the same make as the existing one as there are TWO different manufacturers of 1.8" HDD's and they each use different ribbon connectors, 80Gb is currently the biggest.
The CPU is soldered to the Mobo, so a CPU upgrade is just not possible.
