I have a NVIDIA GeForce GT330M Graphics Card installed on a F Series Sony Vaio.
Is it possible to upgrade the card...?
Solved! Go to Solution.
Hi almorga15 and welcome.
Sadly laptop graphics cards are chips soldered into the motherbard which cannot be economically upgraded.
However, you can upgrade to the latest driver version as described above.
Sorry I misunderstand you message I reckoned that you were speaking about the drivers... It is no possible to upgrade the card in a laptop generally speaking.
Sorry I did not read your message properly and I thought that you were referring to upgrading the drivers, not the card itself.
Even so, that is good advice about the drivers joperez7790. Probably updating the drivers will help.
