Upgrade options for Vaio Duo 11 - SVD1121Q2EB
alper-tr
Hello,
I have a Sony Vaio Duo 11 with a model number of SVD1121Q2EB which has a 4gb memory and 100gb SSD. I would like to upgrade its SSD and Memory.
1) May I increase its memory? Some pages saying that I can get max 8gb, some says there is no way. How can I check the slots?
2) May I increase the SSD?
3) May I upgrade it for Windows 10? In past, there was a warning notice, what about now?
Many thanks!
Marino.Manolo
Genius
Hi @alper-tr,
1) No, the maximum supported memory is 4 GB: https://www.sony.co.uk/support/en/content/cnt-specs/SVD1121Q2E/list
2) Yes, you can... The actual SSD is a "normal" SSD mSATA.
3) For the Windows 10 Upgrade:
