upgrade VGN-FE31M Memory
soul-salien
Hi there.....i would like to upgrade my notebook´s memory. Model VGN-FE31M and
want some advice if I can change.....
Actual configuration:
Memory Speed 533 MHz
Type DDR2 SDRAM
2 x 512 Mb
To:
Memory Speed 667 MHz
Type DDR2 SDRAM
2 x 1 Gb
I will have any problem changing from 533 MHz to 667 MHz? Is the motherboard will support
that kind of memory speed?
cheers! :wink:
soul-salien
can anyone please help....I think it´s a easy question........yes or not?
Hi soul-salien,
Yes, your FE31M will accept 2GB of DDR2 667 memory.
Use a company that guarantees compatibility.
£32.89 from CRUCIAL.COM
:wink:
