Hello,
First of all i have a Vaio laptop model: VPCEB3C5E with an intel core i5, 3GB Ram and 286GB HDD, and what i want to do is upgrade the Ram to 8GB and instead of a HDD, i was thinking of a 250GB SSD, more specifically this one:
http://www.amazon.co.uk/Samsung-Series-250GB-Solid-State/dp/B009LI7C9Y/ref=cm_cr_pr_product_top
The samsung 840 series 250GB 2.5inch SATA. The question is will it work with my laptop? Will it fit, and work with the motherboard etc... I have a windows 7 64bit so the Ram should be fine right? If any futher details are needed dont hestiate to ask!
Regards
Message was edited by: TheYousif5
