please can anyone advise me about the problem, recently i had approx 3500 mp3's loaded taking up 12gb then the status bar in sonicstage 4.2 showed this in green and an additional segment in blue which according to the device info it was now 27gb used ?? also i cannot upload to it although windows xp home sees it and sonicstage plays from it when i try to upload the transfer box appears and then just fades away without loading. any advice would be appreciated. i have formatted my pocket (even though it hurt to do so) and downloaded and reinstalled 4.2 version again with no result
Hi Lanka, Welcome to CV.
Have you tried going through the firmware update process again?
Hi, yes I have done the upgrade and found that the skins weren't much use so i've left it in the standard mode, further to my 1st post I seem to have resolved my problem but I'm not sure how, its seems to be comunicating again after my desktop was able to upload all my tracks again from my aux drive and then I connected it to the laptop and was able to upload most things BUT since I re-installed Ver 4.2 the Connect music site will not let me login using my current details, I think it thinks that this is a new computer and so says politly, go away, which upsets me because I can't access my downloads area and re-affirm the licences and so cannot upload them through Sonicstage onto my pocket, which although I can play them on the laptop I can't do much else with them.
On the connect page there's a link to be sent a temporary password but after clicking and clicking I'm still waiting for the e-mail
otherwise if you have any input then please advise otherwise for now I'm back up and listening and will just live with what i can do
regards to you
Chris Wright
