Hi all, i have a sony vaio pcg-k15bp, its a good 4 or 5 years old and was very noisy so being so clever i decided to take the laptop apart to try and clear the fan out....stupid i know, anyway i removed the fan and put it back together but now it wont turn on, i press the power buton and the two lights (batters and power) flash on and then turn off....nothings boots up at all. I listed it on ebay as i wanted some money for a new sony laptop but am im a student that saving could take a while so now im without a laptop....can anyone please help or give me ideas what to do......if there is anything at all
Many thanks
Sam
Sam, Your going to have to take the laptop apart again to Double check that you have put it together properly. I'm not sure about your model but most laptops have several thin ribbon cables which connect to the Main board, these can come unplugged / Lose if not careful.
Sorry thats all I can suggest
I would cancel the auction or you'll get some angry people venting their spleen.
